packpe89's avatar
packpe89
Air Bag Problem
My son recently got a truck that came with air bags. Somewhere around a 2013 Ram. They do not tow with it, but I'm guessing the previous owner did. The truck has started to squat in the rear, I'm guessing a couple of inches at the tailgate below level. Pressure at the airbag gauge is 50-60 psi. If you blow them up to 90+, the truck will level, but be back the next day. So, I'm guessing there is a leak somewhere, but it goes down on both sides. Would think the air bags are independent??? Also, shouldn't the regular shocks keep the truck from squatting without a load?? So maybe new shocks are the answer? Can't post pictures as the truck is a couple of hours away.
Thanks.
  • Shocks aren't the problem. Probably an air leak. They are not independant of each other.
