rtaylor0830 wrote:
I am thinking of putting airbags on my 2015 f350 it rides fine but it squats when I let the weight of the toyhauler. My question is how much air needs to be put in and how hard are they to install. Also when you get to a campsite do you need to let the air out and refill them after hooking back up to leave. Will a small compressor work for this. I don't want the onboard compressor.
Any reason for no onboard air, I did on my first set of airbags, that manual inflating ,deflating it got old . Installed the onboard compressor after about a year of the manual thing. Have had onboard ever since when installing airbags.
Big thing for me is the ability to change air pressure on the fly for different road surfaces. It was an experiment thing for me at first ,but found that changing the air pressure I could smooth things up a bit, pretty tough to do when manual inflating. You may get lucky ,and find the correct air pressure after a few trips, but still unable to really do much else.
IMO its well worth the investment. This last time I went with a remote control air system . Didn't have to run air lines or electrical inside the cab, and having to find a decent place for the air gauge . Just a remote to change air pressure that clips on the sun visor or in the console.
