BubbaChris wrote:
..snip.....
When you first fired up for a test, your converter could have been drawing a bunch of power to charge your batteries. So having that draw AND trying to start the A/C was a no-go.
....snip....
That is most likely the problem. Learn to switch the refrigerator to gas and shut off the converter if you want a good chance of operating ac with Honda 2000. Took me a while to learn this. Another trick is to set the thermostat so low that it will not cycle. Harder restarting when everything is heated up and pressures are higher.
