Gr8life wrote:
BubbaChris wrote:
..snip.....
When you first fired up for a test, your converter could have been drawing a bunch of power to charge your batteries. So having that draw AND trying to start the A/C was a no-go.
....snip....
That is most likely the problem. Learn to switch the refrigerator to gas and shut off the converter if you want a good chance of operating ac with Honda 2000. Took me a while to learn this. Another trick is to set the thermostat so low that it will not cycle. Harder restarting when everything is heated up and pressures are higher.
the batteries are all disconnected
