Joeljpz's avatar
Joeljpz
air conditioning
have 07 wildwood travel trailer with round vents in ceiling for air conditioning but yet air come out of the vent by intake and dont see way to close it, any help please
  • azwildcat wrote:
    There should be a slider vent on the face of the unit that you can use to divert the air to the ducting. Just slide this vent closed.
    That should be the answer. Note. the tab used to slide the vents, is very small.
  • If that does not work, take the ceiling assembly down and inspect. It should be obvious where the air is directed. There are probably 4 to 6 Phillips head screws holding it in. You will need to pull the control/adjuster knobs off first, just pull hard.
  • There should be a slider vent on the face of the unit that you can use to divert the air to the ducting. Just slide this vent closed.
