ShinerBock
Dec 05, 2017Explorer
Their reasoning behind that is the ECM monitors EGT's and will defuel if they get too high so you have to worry about EGT's. This is of course if you are stock and if you alter the tuning to turn these safety nets off then you are responsible for monitoring your engine.
You can buy an EDGE Insight or other monitor as a gauge to pull the data from the ECM, but the factory pyro is post turbo. If you are deleting your EGR system then make sure to get one that has the EGR cooler block plate with a hole already tapped for a pyro and you can by the EDGE EGT pyro for the Insight. One side note, deleting the EGR cooler will cause very bad drone so I would look into an FTE resonator as well.
