JoeVita's avatar
JoeVita
Air in Water Lines
I need some advise on ways to find an air leak in fresh water lines. One dealer replaced the pump filter which didn't help. Another replaced the pump which also didn't help and they put my original one back in.
Somehow I need to pressurize the system and search for leaks. Any suggestions will be appreciated.
  • Usually it's the line( hose )from the water tank to the pump . Check the fittings/clamps first . If not that the hose itself may be porous or have cracked ends . Sometimes you can just cut the ends off and re-clamp .
