- TimtationExplorerI use a vacuum, you only need to get enough out to leave room for freeze expansion, like lung power as previously posted.
- I run about 25 PSI
- rbpruExplorer IIFrom experience I would say it is less than what I used when I blew the check valve out in my camp water line connector.
My compressor is maxed out at 60 lbs. - tatestExplorer II
CopilotCompanion wrote:
tatest wrote:
I crank the regulator on my 150 psi compressor down to 25-35 psi for this task. Blowing out one water line at a time, it is unsual for this to empty the (not very large) tank, and if the compressor has to start running, it has enough output to maintain flow at this pressure setting. For his job, what you need is air volume, not pressure, since you are blowing out open lines and not building up pressure.
Off topic... Are you the voice-over guy?
Right to the point. Are you the new moderator? - TUCQUALAExplorerNo labor costs, no parts costs, just some extra time to be sure you hit all lines and faucets!!! Of course with your tiny home, you could blow into the hose and take care of the lines!!!!!
- Colo_TJExplorerBut there's plenty of room for the remaining moisture to expand.
It doesn't need to be dry. - TUCQUALAExplorer25-40 psi, AND, do it 2 or 3 times!! Water vapor will condense in the low spots and elsewhere in the lines!!!
- CopilotCompanioExplorer
Off topic... Are you the voice-over guy? - tatestExplorer III crank the regulator on my 150 psi compressor down to 25-35 psi for this task. Blowing out one water line at a time, it is unusual for this to empty the (not very large) tank, and if the compressor has to start running, it has enough output to maintain flow at this pressure setting. For his job, what you need is air volume, not pressure, since you are blowing out open lines and not building up pressure.
- SAR_TrackerExplorerand remove any installed filter elements, and empty the filter housing....
44,066 PostsLatest Activity: Jul 25, 2018
