Alaskan_Fly_Guy's avatar
Oct 01, 2016
Air Pressure for blowing out lines for winter
I know it is on here somewhere but what is the pressure to use for blowing out tank/lines for winterizing. I have a 150 lbs compressor but I think I remember that I need to adjust it to 25-30 lbs max for blowing out the lines?
  • I have tried 35 to 50 and actually find 20-25 works much better.
  • And don't forget to blow out the shower head. I learned that this past spring when we found it laying in the tub!
  • ktmrfs's avatar
    ktmrfs
    Explorer III
    Trackrig wrote:
    Use 35 - 40 psi, the same as water pressure.
    If you have a black tank cleaner, be sure to blow it out also as it's not connected into any of your water systems.
    Bill
    x2.
  • Use 35 - 40 psi, the same as water pressure.
    Bill
