Camper_Jeff___K
6 years agoNavigator
jimh425 wrote:Camper_Jeff_&_Kelli wrote:
F250, 3000 pound TC, stock leaf springs, 75 pounds air in the Firestones got me level.
Same setup but now with 6 plus 1, 5500 pound springs installed, 15 pounds in air bags. Ride is much better.
Probably weighed a lot more than 3000 lbs or your springs were completely worn out.
Camper tag says 2945 pounds wet weight. I installed the new heavier rear springs because the left side was 1-3/4" lower than the right. I had a list to the left going down the road. The new heavy rear springs corrected that. The front left is still lower than the right. I plan to install new front springs too which should correct that.
You may remember this installation video.
44,070 PostsLatest Activity: 1 hour ago
