lmarcrumExplorerJul 22, 2014Air pressure?When towing with my conversion should I set the air pressure on the van tires at the 42 psi recommended by Ford or the max setting on the tire at 50 psi. Thank you
RinconVTRExplorerJul 22, 2014Use what Ford recommends or max cold PSI stated on the tire. You cant really go wrong with either one.
Related ContentAir Bag Pressureair pressureMaintaining air pressure in your tiresAir Pressure 19.5 tiresAir Conditioner vibration
