- Art_SchlangenExplorerHMS No never tried it open. Always close. Did not effect the clearance they are approx 1/2 inch in dept. Maybe a inch.
ART - HMS_BeagleExplorerVortex generators create turbulent flow. Turbulent flow is much better at sticking to surfaces and following curves, hence (the theory is) will close in behind a blunt shape more quickly, reducing the size of the separation bubble behind it. So they should themselves cause a little extra drag, but the reduction in drag due to the smaller separation bubble you are dragging behind more than makes up for it. That's the theory.
I am surprised that it made a big difference placed under the overhang on a camper, but airflow around a complex shape is not easily predictable - even with super computers and software costing hundreds of thousands of dollars. Nothing like an experiment! I have a Bigfoot on a 1999 ford that looks very similar to yours, I think I may try it!
Did you notice any difference in noise with rear sliding window open/closed, before/after the air tabs? We don't have a huge increase in wind noise with the camper, but much more if the window is open. Even with a foam boot in place for the cat crawl through.
How tall are they, i.e., how much did they reduce your camper/cab clearance? - Art_SchlangenExplorerPianotuna Awesome I look forward to everyone's results. I did not want to screw into my camper so that is a big reason I use these, Figure it did not work I could remove them. But going to add more. ART
- pianotunaNomad IIIHi,
I put mine as close to the end of the RV as I could. I did have to trim one air tab on each side due to a clearance light. - IAMICHABODExplorer III
pianotuna wrote:
Hi,
Mine are on the sides and top of the RV at the rear as recommended by the air tabs folks.
This is not my "ride" but is where I placed my tabs.
Thanks,The reason I wanted to see yours is that I wanted to see if you put them before the piece that joins the side to the end cap.
I have no room behind that joint to place them because it is very short and if I put them before it I think they will not be have enough air flow to make them work because that joint is 5/8 in. tall.
Does that sound right? I don't know how much that would disrupt the vortex efect if it is blocked in any way. - pianotunaNomad IIIHi,
It reduced the noise level dramatically. There is improved mileage when traveling with the wind, but very little difference when driving into the wind.
I did not have handling issues so I did not notice any difference in handling. - Catlin98987Explorer
pianotuna wrote:
How did it work?
Hi,
This is not my "ride" but is where I placed my tabs. - pianotunaNomad IIIHi,
This is not my "ride" but is where I placed my tabs. - IAMICHABODExplorer IIIHi pianotuna
I am interested in these too,could you post a picture of yours so we could see how you did it? - pianotunaNomad IIIHi Art,
Thanks for the picture. I guess I'll have to try some in that location on my cabover. The ones on the rear did make a huge wind noise difference.
44,066 PostsLatest Activity: Oct 04, 2013
