GordonThree
May 22, 2020Explorer
Airbag fill ports?
For those with a manual aftermarket system, where did you put your fill ports? Suggestions? I'm not interested in drilling anything that's metal on the truck.
GordonThree wrote:cummins2014 wrote:
Ram truck ?? If so ,then its the same as mine ,plastic behind the license plate , I must of just drilled out the holes. No holes in mine either on the bottom . Just the top two
Maybe I misunderstood your earlier postcummins2014 wrote:
As said above ,no need to drill holes, they are already there in the license plate .Remove the license plate bolts insert the valve ,and put a nut on it, and cover with a plastic valve cap, couldn't be easier ,and acceable .
