Ron_Gratz
Apr 29, 2013Explorer
batman99 wrote:Trying to understand your process and have some questions and comments:
Let most of the air out of air bags. Only leave 5 lbs in them. Connect Pickup to the Trailer and connect WDH as well. The rear of a pickup will go DOWN. This is normal. Keep adjusting the WDH until the connected trailer's "stance" looks good. Now, add previously recorded air back into the Vehicle's Air Bags. This will get your Tow Vehicle and Trailer to the scale.
1) You use the WDH to raise the rear of the TV until the TT's stance looks good. What is the attitude of the TV at this point -- rear lower than, equal to, or higher than its unhitched height?
2) After adjusting the WDH, you add back air to previous pressure. I assume this lifts the rear of the TV and the TT's stance no longer looks good. Now, what is the attitude of the TV relative to unhitched?
At the legal scales, adjust the WDH system until proper amount of weight is distributed across the Tow Vehicle. Record the air bags lbs. Record the WDH adjustment (like number of links or number of showing threads). Put this paper in your TV's glove box. Next time your load up Tow Vehicle and Trailer with similar loading, use the same adjustments.3) What is your criteria for determining proper amount of weight distribution? Does this second WDH adjustment process usually add load to the steer axle, or does it remove load from the steer axle?
4) Do you add any air to or remove any air from the bags while at the scales or while the TT remains attached?
5) What are your criteria for desirable TV and TT attitudes at the end of the air bag and WDH adjustment process?
Thanks,
Ron
44,071 PostsLatest Activity: Aug 30, 2026
