Ron_Gratz
Apr 30, 2013Explorer
RinconVTR wrote:If you attach the trailer to the TV and then apply load to the WD bars,
They are not in disagreement if you add air for added spring rate (or added support from bottoming out, or excessive travel...however you want to view it), NOT adding air to the point you induce lift when WDH is attached.
the rear end of the TV will rise up to a certain level.
How can you then increase the pressure in the bags without causing the rear of the TV to raise more?
Ron
44,071 PostsLatest Activity: Aug 30, 2026
