Ron_Gratz
May 03, 2013Explorer
W.E.BGood wrote:Thanks for the contribution.
---The WDH was correctly set-up and adjusted for the trailer prior to the airbags being installed.
How do you determine when the WDH is correctly set-up?
Did you notice if there was any change in the rear-end height when you had 60 psi in the bags versus 25 psi?
If you ever get the chance, it would be great if you could measure the TV's axle loads, with WD applied, for 5 psi in the bags and then for 60 psi.
Ron
44,071 PostsLatest Activity: Aug 30, 2026
