CptnBG
Feb 10, 2015Explorer
Alignment Question
Assuming the TC will be on the truck about 50% of the time would you get the alignment checked with or without the camper loaded?
Super_Dave wrote:For the most part, I agree. The problem comes in when you do have alignment problems, why? Was it due to TC weight, normal wear, hitting one hole too many, or?
To some degree, I think you'd employ the "if it ain't broke, don't fix it" mentality. If getting it aligned with the camper off hasn't resulted in any odd tire wear with the camper on, I'd probably stick with that approach.
