CptnBG
Feb 10, 2015Explorer
Alignment Question
Assuming the TC will be on the truck about 50% of the time would you get the alignment checked with or without the camper loaded?
ticki2 wrote:I agree. Do not get me started on the value of airbags. Simply stated, they can correct this. With all due respect, this subject as it pertains to Airbags goes way over most folks heads. Fact is, in my opinion, the adjustability of airbags can provide more than a fixed spring upgrade setup. It is difficult to discuss/argue due to most peoples beliefs in one liner solutions.
... I agree that 200#+or- on an average 4000# front end isn't going to affect the alignment that much , mostly the camber but that is only one factor . The rear end being high , low or level in relation to the front end will affect the caster angle which in turn affects the steering stability at speed .
