CptnBGExplorerFeb 10, 2015Alignment QuestionAssuming the TC will be on the truck about 50% of the time would you get the alignment checked with or without the camper loaded?
twodownzeroExplorerFeb 12, 2015It also depends heavily on what kind of suspension your truck has. A solid axle "alignment" is pretty much limited to toe unless it's way out of whack.
Related ContentCaster Question (Alignment) AgainAlignment shopBed alignment bracket questionsAlignment questionTires & Alignment
