HMS_Beagle
Jul 03, 2014Explorer II
I have seen no indication from Heki or any of their dealers that there are three versions of the Heki Midi (specifically). There are a number of different Heki skylights other than the Midi, of various vintages, so maybe that is the confusion (Heki 1, 2, 3 Plus, 4 Plus, Mini Heki S, etc., also the Heki Midi Style which opens sideways). In fact the one shown broken in the posting above does not appear to be a Midi, but a different model. I should clarify that there are actually six versions of the Heki Midi manufactured concurrently: a bar operated, a crank operated, and a motor operated version, each supplied in two variants: sealed and permanently vented (required by some European jurisdictions). But none of these is an improved version of the other, merely model variations within the Midi product.
From Dometic's website, parts breakdown for the Heki Midi shows only one configuration, one set of parts. I would be interested in any information you have that shows otherwise. Surely the product could be improved!
On edit, I notice the OP did not specify which Heki skylight he has. Could be one of the others I suppose. The 1, 2, 3, and 4 all fit the same rough opening.
44,071 PostsLatest Activity: Aug 30, 2026
