mkirsch's avatar
mkirsch
Nomad II
Jan 30, 2015
Aluminum Body Panel Conductivity.
Supposedly my new Chevy Silverado has an aluminum hood. I haven't verified with a magnet yet but I have noticed an interesting phenomenon:
The snow melts off the hood and front fenders when the engine is warm!
It started snowing when I got home last night after work. Two hours later I went to get groceries, and the rest of the truck was coated in snow.
I've never noticed it before on the steel-hooded trucks. There may have been less snow, but never no snow... This has to be because of the better thermal conductivity of aluminum vs. steel.
Anybody with a new Ford notice the same thing?
  • Lessmore wrote:
    Dog Folks wrote:
    RoyB wrote:
    Wonder what problems will come up using the aluminum frame on the new F150 for battery negative cable frame ground connections.
    Roy Ken
    Aluminum was used for a while in house wiring so it conducts electricity very well.
    We have aluminum wiring in our house. It's no longer used in houses. Copper wiring is regarded as better wiring. We haven't had any problems...touch wood...with out aluminum wiring, but I wish we had copper instead.
    Not so much of a problem with the aluminum wiring itself. The problem is where the aluminum wiring is connected to the copper wiring. If the proper connectors are used, there's no problem.
  • Dog Folks wrote:
    snip....
    As others have said, the frame is steel so the point is moot.
    ALU is no longer used much any more in home wiring
    Too many fires
    Creep, oxidation, larger gauge to carry amperage than copper and
    that most of the electrical connectors were not designed for both
    copper and ALU
    When I was still a designer...remember that there was a NEC notice
    about that. Don't know the current status as haven't been a designer
    for decades. Think my reference copy of the NEC code book is dated
    in the 70's
  • Dog Folks wrote:
    Roy Ken
    Roy Ken
    That is the whole point...the battery it becomes when the two metals make an
    'electrical connection'
    Why it takes a specially trained body shop to work on it...biggie is that all
    the fasteners MUST be either plated correctly and/or SS...but SS doesn't have
    as high a grade rating as steel fasteners
    That 'electrical connection' can be direct contact or via an electrolyte (salty
    water is a good one)
    Galvanic corrosion is an electrochemical process in which one metal corrodes preferentially to another when both metals are in electrical contact, in the presence of an electrolyte. This same galvanic reaction is exploited in primary batteries to generate an electrical voltage.
    Ford pickups have had aluminum hoods since 1997 ....
    The heat from the block (engine) heater alone will melt the snow off the hoods of many vehicles.
    Roy Ken
  • RoyB
    The frame on the new Ford F150 is steel. Only the body is aluminum.
  • RoyB's avatar
    RoyB
    Explorer III
    Roy Ken
  • My Expedition has an aluminum hood and I have not noticed much difference.
