sleepy
May 26, 2013Explorer
LannyV wrote:sleepy wrote:
Contact Lance... they will email you schematics of your walls, ceiling etc specific for your camper. Have your serial number on hand when you contact them...things change even within models.
I've seen side mounts and rear mounts... stand-off bracket to the side of the ladder.
Good luck!
sleepy
Thanks Sleepy, I have already contacted Lance and as you said they emailed me a complete set of schematics on where all the framing is, info on the electrical and plumbing, but it does not indicated where they are run in the walls or ceiling. I am thinking of mounting it on my luggage rack and running the cable down the ref vent but concerned about heat or maybe enter from the side and use a clam shell like they do for boats but what to get an idea how other may be installing.
Lanny
The wiring from my solar panels runs through a special adapter under the refridgerator cap... then down to anare under the cabinates. Their isn't enough heat to bother the wires...
So I think your plan will work... and no punctures through roof or walls.
