whizbang
May 27, 2013Explorer II
I ran an HF station from our rig. Rather than drill antenna mounting holes in the camper, I made a bracket that clamps to the ladder. The antenna mounts on the ladder bracket. Do a search "over 12 months" for better photos. I borrowed the idea from someone on the forum.
Other than than, take your time routing the wiring. If you look around long enough, you will be amazed at the gaps and grooves you will find that are large enough to pass coax and power cables.
