msiminoff's avatar
msiminoff
Explorer II
Jan 09, 2016
Amazing MPG gains... Magic fuel, or ???
I have driven 6975 miles since setting out on this cross-country trip back in early October, and I have recorded every single mile and each gallon of diesel fuel along the way (22 tankfulls so far) in my log book. On average I get a hand-calculated 11.65 miles per gallon and the overhead console's "Lie-O'-Meter" usually displays ~14.4 MPG. I do always fill my tank all the way up to the top of the filler neck.
However on three separate occasions (over 4 tanks of fuel) I have gotten much much better fuel economy... in the neighborhood of 13.55 MPG (and 17.0 showing on the overhead). That's an unbelievable 16% increase!!! To make things more interesting, while getting better mileage, the truck feels more "peppy" and it seems to smoke less too.
The first time this happened was near White Sands NM (fuelled-up at a Texaco station). I had just adjusted the rear tire pressure (from 105 up to 115)... and we had traveled to a slightly lower altitude over the course of the day. So I just assumed those things contributed to the improved economy.
The second time it happened I was driving across west Texas at a constant 65 MPH and there was almost no change in elevation. I chalked that one up to my gentle use of the skinny pedal.
Now this third time I am in the Florida Keys (= sea level). I drove down here from the Palm Beach area and got my usual ~11.6 MPG, but after fueling up the overhead display suddenly started lying to me again and displayed 17.0 MPG. Sure enough when I refilled the tank, I got 13.5 MPG.
Now here's the really interesting part; This is the first time I have re-filled at the same gas station twice in a row (a Chevron in Marathon FL, in case you're wondering). On the second tank I drove up to Miami and back and low and behold I got the same improved fuel economy (both directions). Same roads, same speeds, same elevation, same temperature and humidity levels, same weight on the truck, etc.
One very interesting tidbit is that the diesel pump at this particular Chevron has a sticker on it that says " Fuel contains up to 10% ethanol". Hhmmmmmm ???
So... what's going on here? How can it be possible that some occasional fill-ups yield 16% better economy, yet all of the others are super consistent? Any chance that some gas stations are selling better diesel fuel that others? Is it my driving? Altitude... speed, weather conditions? Could I be getting a winter diesel blend? Defective odometer? Is this just a fluke?
And what's the chance the addition of ethanol has somehow helped? This seems unlikely to me since ethanol has far less BTU's/gal than #2 diesel.
I sure would like to be getting this improved fuel efficiency all the time.
I am stumped! Please share your thoughts.
Cheers
-Mark
