LarryJM wrote:
KS56 wrote:
Just stumbled upon the 'Andersen-3604 Camper Leveler' while searching for an easier way to level my travel trailer. Sounds like a brilliant way for side to side leveling.
Not happy with the plastic 'lego' type blocks that I am presently using. I'm on my second 10 block set and they keep on breaking!
Any comments on the Andersen-3604 Camper Leveler from someone that is familiar with them would be greatly appreciated.
How in the world are you breaking those lynx leveler blocks ... I have three sets that I use to make ramps for my 1T Van and can't envision how they woould break. Personally, I don't like the concept of the small amount of ground contact with that Anderson system since the PSI at "ground contact" has to be MAGNITUDES larger than something like the Lynx levelers and they would sink like a rock on soft ground.
Larry
Note: The op asked for comments from "someone that is familiar with them". That is obviously not you!
Now picture your lynx level blocks, the contact surface is a spider web, not solid, I have buried them in soft ground many times.
I have a set of the Anderson Levelers and the contact surface is solid, they are no more likely to sink that your tires. I have relegated my level blocks to under the stabilizer jacks.
Are you comparing your 1 ton van to a 3, 4, 5 or more ton RV?
