wnjj
Nov 10, 2015Explorer II
rockhillmanor wrote:billtex wrote:Stars101 wrote:
I take the view that as long as it gets well above freezing during the day that the lines/pump will be fine.
2X...Never had any problems with this method.
:S
What the temp is at noon the following day has NOTHING to do with water freezing during the night where the temps DROP to freezing. What school did you all go to?! :B
Here think about this,
Put ice cube tray filled with water in your freezer.
Within just a couple of hours they are frozen and expanded in the tray.
NOW 'carefully' take them out of the freezer and bring them into you house heated at 78 degree.
Did taking them out of the freezer into your warm house PREVENT them from freezing?? NO!
And neither will the sun coming up the following day PREVENT your pipes from freezing overnight in 32 degree temps. :R
Bad analogy. Try putting those ice cube trays into a cooler and then put the cooler into the freezer with the freezer at 32, not 0. They won't be frozen for hours. Basic thermodynamics says the warmer and more insulated something is, the longer it will take to reach the ambient temperature.
