Stars101
Nov 11, 2015Explorer
I have a Travel Leak, sorry Travel Lite. Entry level. Minimal insulation, but I will work on this. It will be a learning curve for sure. I am just planning on having a working furnace and porta potty this year.
But next year I hope to be able to use the water system to the shower only... no need for using the kitchen sink since it's within arms reach of the bathroom LOL. I can hold the bathroom faucet and kitchen faucet both, if I stretch a bit. That way I will only have one set of lines to deal with.
My biggest issue would be my small grey tank. It's 5-6 gallons directly under the shower pan. And I don't know what the plumbing looks like between the outside dump valve and the inside... so if a line split there I would be in deep doo doo.
All the other lines are visible and open to the interior. They run under the dinette edge, if you reached down you could feel them. And the hot water heater is in a cabinet that open to the inside of the TC.
It might prove an easy TC to make winter useable if I can stuff enough insulation in it.
I have a few wireless temperature probes that I will experiment with so I can see just how cold the water pump gets.
