basmit1ExplorerMay 14, 2014Anode RodI have used the same anode rod in my Suburban water heater for four years and it is in the same condition as the day I put it in. Why is it not being depleted.
westendExplorerMay 14, 2014You can check for continuity between the anode rod and the tank but I believe calamus had the answer, wherever you're filling up is good water.
