prichardson
Aug 10, 2016Explorer
You probably have more draw on the 12V system than you realize. Deploying the slides is a significant drain, a radio with remote or clock has constant drain, LP detector has constant drain, Fridge and water heater both have small constant drains when on. On most break-away switches once you replace the plunger you are good to go.
