korbe
Aug 10, 2016Explorer
First thing we did when we got our new to us rig, which had a lot of new fancy things on it that our previous 1976 5er didn't have, was to test the amp use of each 12-volt devise at the battery. With the use of a cheap digital volt meter that had the ability to test amperage, we would turn on then off each devise to give us an idea of what to expect while dry camping. It also told us of the normal parasitic loads.
In your situation, we don't know if what you are doing alone is draining the battery, or if something else is going on.
One thing that came to my mind was if the frig humidity switch was on That would use up the battery pretty fast. Your frig may not have one of those however.
