Scott608
Aug 10, 2016Explorer
beemerphile1 wrote:Scott608 wrote:
...while setting up someone accidentally stepped on the emergency break-away and the plunger came all the way out. I put it back in no big deal....
That is very likely the problem. If the electric brakes are engaged it will drain the battery quickly.
There is no reset needed but the pin has to be put back in with the correct orientation to open the contacts.
That's interesting. I just double checked this and the plunger can only be inserted in one direction. I'm so frustrated by this I hate not knowing.
