Oldcow's avatar
Oldcow
Another brake thread
I have done some research but would still like to ask questions. I have a 2013 Out.back 300rb weighs in at 7600#'s empty. I tow with a Tundra and use a Prodigy P3 controller.
Brakes are only 10 inches and are not the best on a good day, so I am told. Had the bearings done this spring and the brakes started acting up after that. Took it back and checked for grease on the pads, none. The brakes looked glazed so the shop replaced the shoes and back plates at cost and did not charge me any labor. They also replaced all of the wiring front to back (something that was suggested on this site, at least eliminate it as a cause).
The issue is that the brakes still have a tendency to grab. I have the setting on B3 as indicated on line by Prodigy. The brakes work fine when I try them manually at 30mph and when I apply lots of pressure on the pedal. When braking gently in town is when they seem to grab.
I would like to know from others who have a P3 what setting they use? When the shop checks the controller using a plug with lights in the brake hook up on the truck all seems good. Could it show to be working but maybe its not working like it should? Perhaps I should try another controller in case mine is defective? Its now only 3 years old.
Thanks for any input.
Oldcow
