Grit_dog
Sep 23, 2014Trailblazer
You don't mention if you are looking for a new or used truck. As stated, the cost difference between 2500 and 3500 srw trucks is negligible, as is the advantage, other than heavier rear springs.
Take that into account when purchasing, as you can upgrade a 2500 to 3500 capacity (real world, not gvwr stickers) for $500 or less.
I would get a 3500 in an apples to apples comparison just because bigger is better but not at much of a cost premium.
This is more important if buying used because you want to get the most truck for your $. Since the chassis and running gear are the same save for added rear suspension capacity.
IMO focus on miles, maint records and condition for a used truck more than the badges on the fender.
My other reccomendation would be to get a long bed truck if the camper will fit it. More stable with the longer wheelbase and less rear overhang on the camper.
An 825 is a pretty light camper so you're good either way though.
44,066 PostsLatest Activity: Mar 14, 2015
