parker_rowe
Jul 13, 2017Explorer
Gdetrailer wrote:DinTulsa wrote:Gdetrailer wrote:Chris Bryant wrote:
It's going to have to have a turbo for the rockies to really cut it.
You do realize that the 6.2 has NEARLY THREE TIMES more HP and torque than say a 1970's - 1990's gas engines that were available in pickup trucks back then.. Many of those big blocks in pickup trucks back then barely had more than 150-160 HP..
Yeah, they ate fuel and went slow, but they got the job done..
Now days folks seem to think you must drive 80 MPH up 10% grades with 20K of weight and never slow down even one mile an hr..
I have a 2013 6.2 3.73 axle and let me tell you it PULLS, I tow 7K TT and even on 9%-10% grades it has plenty of snot left for more..
Yeah, I do understand at higher elevations you will lose some power but really if you lose say 10% of your HP that amounts to about 36 HP which is nothing when you are starting out with 360 HP to begin with..
If one was going to make it a habit towing at high elevations with 10K lbs or more that then go with 4.10 axle with the 6.2..
He's looking at a 12-14k 5th wheels, he will need the 4.10 axle to cut it on flat ground. I'm not bashing the 6.2, I think it's a great engine, but that's a lot of weight.
While it won't be sporting up the mountains at 80 MPH, I am sure it WILL pull it.
Heck, if my Dad could tow a 11K 5th wheel with a lethargic 1980 F350 with 150 HP 400 CID non fuel injection engine with 3 speed C6 transmission up 10% grades at 75 MPH I am sure the OP should be able to at least tow 14K with 365 HP with 6 speed transmission up 10% grades while maintaining at least 50MPH-55 MPH..
YES, it WILL lose some speed, YES, it isn't going to win any races, YES, it WILL be running high RPMs, YES, it WILL gulp fuel, YES, IT WILL BE NOISY, but it WILL get the job done.
Folks now days are plain dirt scared to hear an engine scream, IT WON'T HURT THE ENGINE to run 4K, 4.5K or even 5K RPMS for a long time. That engine IS BUILT to operate at those RPMs.. It IS the reason why Ford DERATED the 6.2 in the F250 and F350s..
As a side note, I HAVE towed with a 2003 5.4 F250 as much as 10K lbs on my flatbed trailer.. As a refresher, that year was a pretty weak 265 HP 2V 5.4.. topped a 12% 1 mile grade at 45 MPH.. NO "running start" at the bottom, has a STOP LIGHT NEAR the bottom of the hill and ALWAYS end up hitting that RED LIGHT..
Love this post.
