Jackfate's avatar
Jackfate
Any one lower their tt
This being my third tt , they just keep getting higher. One thing I know is the higher it is the worse it handles. Even a n inch would helpful . Change springs? Shackles? I know people lift them. I understand theirs limits.
Just wondered
  • The longer they get, the higher they are as well, for clearance. If you're towing a longer tt you're going to be dragging a lot if you lower it.
  • nohurry wrote:
    Just wondered
    Does yours handle badly?
    If so, it likely isn't the height. Might check hitch weight, and setup, and/or weight distribution in TT. Anyway, as has been said, the floorplan has dictated your trailers height. Whether it be a slide, or just an open floor space above the wheels, it was designed, and engineered that way, and I wouldn't try to change it. Good luck.
    The higher you make it the more Wind effects it
    Just wondered
  • I've all ways liked the '70s GMC motorhome because of the single step entry. (I know it's not a TT, but some one was thinking back then) The cantilever "dual axle" meant they had no axle across the floor.
  • Yea thats the problem with todays builds. There are alot of deck overs with 3 or 4 steps to get in
    I'm in the market for a new trailer and it seems every floorplan I like is unusually tall because of this
  • A lot of them, like mine, cannot be lowered, due to tire clearance issues. My trailer is a "deckover" type of build, meaning the flat flooring deck is built over the tires ( no wheel wells ).
