myredracer
Mar 21, 2016Explorer II
Check to make sure the roller catches are properly aligned and not damaged and that the drawer slides are also aligned right. Saw one TT where the two parts of the roller catch on a cabinet door were about an inch apart and the drawer slides were so far out on a drawer that the roller catch would not engage. Sometimes the screws can pull out. The OEM double roller catches are just not very strong.
If the roller catches are okay, you can add a 2nd one. They should look like in the photo. The metal is very thin and easily damaged. You can replace the standard OEM roller catches with a heavy duty one from RV Designer, JR products or Southco (about $10 each). They come in 3, 5 &10 lb ratings. I'd forget about the magnetic catches - tried them and were worse than the roller catches.
Knape & Vogt has drawer slides specifically for RVs that snap shut and require a tug to pull open. K&N 8400 RV series drawer slides I put them in 2 drawers I installed beside the bed. They are very nice - about $20 a drawer.
If you need to adjust the existing catches or install new ones, use green painters tape to make alignment marks on. More than likely they are not aligned properly or are damaged.
Our TT has a rear kitchen that has a bank of drawers (fore/aft direction) and we've had a drawer open a few times over 2 years and same with large drawers in bottom of our wardrobe in the slide (left/right direction). I've gotta replace the cheap OEM catches with new HD catches one day.
44,066 PostsLatest Activity: Mar 14, 2015
