TomG2
Jul 23, 2015Explorer
APT wrote:
...snip.......Comparing the max payload F-150 package to my 3/4 ton Suburban shows the half ton is more capable in nearly every ratings. My receiver rating is lower by 15-250 pounds. My payload is lower by about 100 pounds. I have 40ft-lb less peak torque, and at much higher engine speeds. I'd pull 7500 pound dry TT with my truck as long as the dry TW was under 800 pounds. So I have no problems recommending the HD F-150 for it either.
..snip.......
Aren't most of the differences simply because you are comparing a Suburban to a pickup truck? How do the two vehicles compare in empty weight for instance?
