Buck50HD
Jul 25, 2015Explorer
mich800 wrote:Buck50HD wrote:greydawg00 wrote:
So based on all comments it looks like I am going f250 or f350. Yes ford because that is what DW likes best. Also I test drove both 6.2 and 6.7. I like the diesel better. It would take a lot to get used to the gas with hp/torque at high rpm after the ecoboost.
I am not happy with the ride in either. The diesel was better I think. Both I tested were 20" wheels with a/t tires. The set on the gasser were fairly aggressive. Plan to try and find or get 18" wheels with a/s tires. Will this help the ride noticeably? Really want to try and make it at least somewhat better. The other thing that bothered me was the steering. It was very unresponsive, almost "loose" compared to my f150. I had to move the wheel a greater distance to do corrections while going down the road. I think this would get tiring while on the highway with semi traffic and constant minor adjustments requiring lots of steering input vs the very small movements of the f150. Any comments on this?
The steering ratio is lower on the super duty so that's what you are noticing. At first I did not like it but it is one of those things that really does not matter and you will get used to it. I find it a benefit when towing because any input has less effect on the rig so if I happen to be watching the scenery instead of the road and my hand moves a little, it stays between the lines longer.
I think it is more that the F150 uses a rack & pinion set up as far as "feel" goes.
That may be part of it but the ratio is lower. Sometimes feels like driving an old dump truck when making sharp turns, needing a few full turns of the wheel.
