MTK251's avatar
MTK251
Anyone haul camper with Ram SRW 3500 2wd factory air bag ?
I have a Lance 850 that I haul on a 2002 Dodge 2500 with upgraded suspension.
Recently I have been looking at 4th Generation Ram trucks. I found a 3500 SRW 2wd that has
the factory air bag system. Just wondering how they would handle a slide in camper that
weighs about 3000-3500? I'm pretty sure you can't adjust the pressures in the bags.
I know how to get the regular leaf spring setup to work. But this new system will probably be hard to modify if it doesn't handle a camper. Any info is appreciated. thanks
  • Not aware of any problems/complaints with the 3500 air suspension. Availability of aftermarket suspension parts/upgrades are much more limited (vs. non-air). Although I don't think it's continuously adjustable, I believe it does have 2-3 presets that will vary the height somewhat.
    My guess a 3500 SRW 2WD should have over 4,000 lbs. of payload in the lower trim levels. May drop below 4k with a higher trim level due to the weight of the additional options. It should handle a 3000-3500 lb. loaded camper just fine. If 3,000-3,500 is the camper's empty weight, then you're probably looking at 4,000 - 4,500 lbs. loaded.
  • The air bags should self-adjust to maintain ride height, which is what most people do with air bags, so it will increase air bag pressure when the TC is loaded. Same effect.
    SRW is not a big issue, yes DRW will be more stable, but so will a class 8 truck…
    You are more than adequate to carry a TC…
  • I'm pretty sure virtually all newer SRW trucks are rated at or near 4k in payload. The 2wd models might even have more than that.
