HMS_Beagle
Mar 27, 2016Explorer
Jack_Diane_Freedom wrote:
Pull the fuse?
Anything you do to disable it causes a beep and notification every time the truck is started.
One solution posted on the net is to cover each of the sensors with sound absorbing foam, but that seems like a lot of work too.
I think my first step will be to experiment with a resistive load on the brake control line to see what it takes to fool it. If that doesn't work or is impractical, I'll buy the Tekonsha unit and take it apart to see what they have in there.
What I want is something I can put in the cable or the camper, so that it does what is is supposed to do: Plug the camper in and it shuts up. These trucks are pretty expensive and sophisticated, I would like it to work the way it is supposed to.
