jefe_4x4
Jul 11, 2015Explorer
Mike,
Newer Dodge's have a lot more fender clearance (trying to stay up with the Ford clearance) compared to my '01 dinosaur (Dodgesaurus Minimus). I too want to go with bigger diameter tires (with 3.55's) and used 3" spacer lift in the front (which has basically the same set up with quad links as you do), and about 3" of lift on the rear springs, all tolled. This brings it level with a loaded for bear TC. The 3" lift on the front coils require dismantling of the quad links just to get the spring compressor and spring between the seats. Just be aware that a 16.5K winch weighs over 150 pounds (with wire rope; less with nylon rope) and any after market bumper or brush guard adds yet more weight to the front end. That''s why i did not pursue the 2" puck lift in front. You will automatically lose much of that 2" lift. Only if you ordered your Dodge new with the snow plow prep package with those stiffer springs would the 2" coil add ons work.
This may not pertain in your case, but the woe with the '01 Ram is the rear of the front fender opening. There is not a quick and dirty way to relocate the axle farther forward, but i think i beat the system by ordering new quad links for a 6-8" lifted axle which are longer. Since they are longer but applied with only 3" of lift it actually located the front axle about 1-1/2" farther forward giving more fender clearance yet where i need it.
Also beware that you may need a little more lift in the rear with the 3" front coils in front. Adding one more upper secondary leaf ( overload) with your Stable Loads may do the trick. Just take it as it comes and a solution will arrive by trial and error..
jefe
jefe
44,027 PostsLatest Activity: Mar 05, 2025
