Mello_Mike's avatar
Mello_Mike
Anyone running with a leveling kit up front?
Here's what I'm thinking about doing. I want to increase the size of my tires from 275/70R18's to 295/70R18's to improve the appearance of the truck and get more weight capacity (an increase of 400 lbs). Doing so, however, will require a 2 inch leveling kit up front to prevent rubbing on full turns. My concern, of course, is running nose high when hauling my 3,000 lb fully loaded TC. I'm curious what others have done in this situation. Did you install Stableloads to alleviate a nose high condition? Just curious if going in this direction would create more trouble than it's worth.
Thanks.
  • I would check your aftermarket rims specs to the stock rims, this is what I have heard makes the difference. If you would like to meet up to look, pm me.
  • GpnAZ wrote:
    Hi Mike - I am running the Toyo A/T 295-70R-18 on my Ram which is the same as yours, no level, no problems, plenty of room. I did some moderate 4 wheeling with camper and no rubbing. These tires drive nice, though are a little more harsh than the stock Firestones and I lost .5-1mpg even calculating the mph difference. I do have them on factory stock rims.
    Hi Mark. That's interesting that you're getting no rub with your 295's on your stock rims. I just got back from Discount Tire and did a test with the 295 Nitto Terra Grappler AT G2's and they absolutely do rub at full turn with my new XD Series zero offset rims. Maybe it's my 450 lb Buckstop front bumper and winch causing my front to ride a little lower?
  • Hi Mike - I am running the Toyo A/T 295-70R-18 on my Ram which is the same as yours, no level, no problems, plenty of room. I did some moderate 4 wheeling with camper and no rubbing. These tires drive nice, though are a little more harsh than the stock Firestones and I lost .5-1mpg even calculating the mph difference. I do have them on factory stock rims.
  • You could use stableloads, timbrens, or air bags. The biggest issue is with taller tires as well you'll be a few inches higher. Not a great thing but you'd probably still be OK. Obviously, lower is less top heavy.
    That being said, be careful about how you level the front. There are some kits that may not hold up. I don't know about Ram ones.
  • Not having a Dodge I can't say anything about them, but I did raise my front by 2ins. I have SS on the rear and the truck always runs level with the TC on or off.
    I had the front end alined afterwards. The headlights did not have to be adjusted.
    Oh I have a Chevy which has a different front end set up over the Dodge.
  • Based on my experience, I sit tail high when emptry and level when the fiver is hitched. If I were to add a leveling kit I think I would see a tail down attitude when loaded. If your that heavy, you might consider changing to 19.5 inch wheels like a lot of folks with 2500 series trucks have done to increase tire loading capacity. Of course that still does not change your truck mfgs GVWR.
