DesertHawk
Jun 21, 2013Explorer
We have a 2009 Toyota Matrix (didn't even know it had a towing capacity-Ha!), but we do like. Mainly for the head room. Others small cars would have greater mpg rating. Not sure about towing capacities. At best we get low 30s mpg highway (more if the wind is going the correct direction). Middle to high 20's in town.
Check the Little Joe & Ponderosa TTs. Very small, yet large beds; made in Colorado. Interior height is at 6'.
Little Joe - not too bad, not as good as the Little Guy for tow weight. Lot more room.
APPROX. WT. 1,100LBS.
HITCH WEIGHT: 180LBS
Ponderosa - not so good.
WEIGHT APPROX 1,480 LBS
HITCH WEIGHT: 180 LBS
Something like a teardrop, a RoughNeck ---- half a Little Joe is very light weight.
Roughneck Specifications
5'3" Wide Body Only
9' Long Body
3' Tall Body Only
6'1" Over All Tall
13'4" Over All Long
Fiberglass Top
5'3"W x 9'L x 3'T - Top Only Size
500 lbs. total weight ---- This is much better.
2" x 3" Box Steel Frame
2 Windows
1 Rear Door
Sorry no experience towing with a small car. Hope you find your trailer.
There are several teardrop trailers manufactures it seems. Many people make there own from plans. Often teardrop trailer show up on craigslist. Not sure if they are lighter if not made of molded fiberglass or not.
The Little Guy Teardrops seem neat. Saw a very small one being towed by a motorcycle one summer.
Another option, an Aliner or Chalet hard sided folding trailers. But you have seem them already. Aliner Alite
Lightest of all Chalet A–frames — base weight of 1150 lbs. Most affordable Chalet. Can be towed by most automobiles. Easiest Chalet to maneuver around campsites and parking lots. Larger & not as light as the Aliner Alite 400, I see.
LTW
Our Daughter & husband have towed Aliners with their Hyundai Santa Fe (all wheel drive). I know you don't want an SUV - this is for the folding trailer quality, not the vehicle. Rented from the Air Force. They are very easy to set up. Our son also rented an Aliner for us to use in Alaska one summer (also from the Air Force). All of these were old & had had a lot of use. But they kept the rain out, even when you could sometimes see light through some 'seams'. Ha! A nice shelter in other words & pretty easy to tow.
An Aliner owner once told us the Chalet A-frames were better built, also more expensive.
A quick search I found this: 1 1/4” Class I Receiver hitch with 1400 lb towing and 200 lb tongue weight capacity. 2011 Mini Cooper Countryman. Not sure of mpg rating for Mini Coopers. Maybe 27/35 mpg?
2012 Hyundai Accent Hatchback Up to 28 cty/37 hwy mpg ? 2013 Towing Capacity:
200 Pound Tongue Weight
2000 Pound Towing
1-1/4 Inch Hitch Opening
But this was from Tow-Tite Hitches. ???
2012 Kia Rio 4 cyl, 1.6 L, Automatic 6-spd, mpg 28 city - 31 combined - 36 hwy
One mpg extra with manuel.
Like above: Trailer Hitch Size: 1-1/4 Inch Hitch Opening. Towing Capacity: 200 Pound Tongue Weight. 2000 Pound Towing. ???
2013 Chevrolet Cruze MPG City: 22 – 28 Highway: 35 – 42
MAXIMUM TOWING CAPACITY - 1000 lbs
2009 Chevy Cobalt towing capacity - 1,000 lbs. mpg is 25 city & 37 hwy.
2012 FIAT 500 with 30 mpg city - 38 mpg hwy. Trailer Hitch Size: 1-1/4 Inch Hitch Opening. Towing Capacity: 200 Pound Tongue Weight. 2000 Pound Towing. Info from etrailer.com - but FIAT USA | 2012 FIAT 500 says Not rated for trailer tow.
Now if you could snag a 2011 Volkswagen Golf 4 cyl, 2.0 L, Automatic or Manuel, Diesel
30 city, 34 combined, 42 Hwy mpg
You would have to do a better search on towing capacities than I tried to be sure on any of this. I got most from etrailer.com which is maybe for the hitch not the vehicles.
Good luck with your quest. Should be able to find the right combination for you.
5'3" Wide Body Only
9' Long Body
3' Tall Body Only
6'1" Over All Tall
13'4" Over All Long
Fiberglass Top
2 Windows
1 Rear Door
LTW
2000 Pound Towing
44,066 PostsLatest Activity: May 13, 2026
