- parkersdadExplorerI think this motor is awesome for moderate towing. I still question how long that small motor will last towing 10 or 11 thousand pounds around all of the time.
- Ncm86ExplorerI have ran a few searches on the ecoboost, some say its great, others have problems and I know here was an investigation. Although a lot of investigations have happened in recent years.
riven1950 wrote:
Yes, Purchased my 2013 in Dec. Has about 5500 miles on it now. Towed from NC to the Keys in Jan / Feb, about 1800 miles or so. No issues at all with the truck or with it towing. It is a CC 4x4 off road with 3,55 gears. Not the heavy duty towing / payload version.
I am only towing about 4000lbs TT, can't hardly tell it is there except gas mileage LOL. Was using a 2004 F150 4.6l before and it did ok. The Ecoboost has way more power off the line and otherwise. Have not towed in any big hills yet but I think it will do fine there also.
I drove the 5.0 and Ecoboost and that made up my mind. Both would do the job for me but ECo has much better low end power, if that is the correct terminology.
BTW there have been several topics concerning ECoboost recently, you may want to run a search and check them out.
Good luck - CarhlrExplorerI just bought one 2014 f150 3.5 eco max tow hands down best 1/2 ton TV I've ever owned to compare it to something else just wouldn't be fair because there is no comparison.
- alexleblancExplorerThree summers and 20,000 km's without issue with my previous TT. For a loaded TT under 7000lbs with the 7700/8200 gvwr F150 with 3.73 gears, you can expect great pulling power, pleasant hill climbing with it's nearly mini Diesel like torque curve and decent unloaded mpg's. The F150 properly equipped is by far the best half ton for towing, I loved mine.
- riven1950ExplorerYes, Purchased my 2013 in Dec. Has about 5500 miles on it now. Towed from NC to the Keys in Jan / Feb, about 1800 miles or so. No issues at all with the truck or with it towing. It is a CC 4x4 off road with 3,55 gears. Not the heavy duty towing / payload version.
Good luck - tragusa3ExplorerI'm very pleased with towing. The low end torque is wonderful. Grades that I used to climb with the V8 screaming at near redline, make the ecoboost downshift once and it accelerates up them at 2000rpm.
Granted, I'm towing less than half of my rated weight. - georgefarl1945ExplorerI have a 2013 Scab - Max tow - 2050 cargo yellow sticker. I pull a 2010 Coachmen (29ft)
26F DSL - #6987 Cat weight - #910 tongue weight - I have been to Gulf Shore a few time - Avg. 9 MPG - The F150 pulls without any problems - I also use a WD hitch ( Equilizer ) - GooExplorerMine's been great. No issues. It's pulled our trailer over 10,000 km so far.
44,056 PostsLatest Activity: May 04, 2014
