- brulazExplorer
skipnchar wrote:
Probably as important is you probably can't get the HD option with the smaller engine so payload will be reduced when the small engine is selected.
The 2.7L EcoB comes with its own "2.7L EcoBoost Payload" package.
The nice thing is that it's available with the 6.5' Bed and SCab configuration, in which the regular HD payload package is not. But it only gets you up to 2160# Max payload, in that configuration, with no options.
I believe it also comes with the 3.73 rear end and a tow rating of 8200-8300#. - TomG2Explorer
goducks10 wrote:
So is the average 3/4-1 ton only good for about 60% of the rated tow rating also. That would mean I could only tow 7440lbs with my 12 Ram 2500 CTD. Not quite following your logic.
I was just using proportions. I don't happen to think that typical F-150's as found on the dealer's lots are good for towing much more than 7,000 pounds. All of this is just conjecture until we see some real world weights and experiences. I have owned F-150's, don't have any idea what your Ram is good for. - dockmasterdaveExplorerI tend to think, towing that big box, if I go about 80% of what the brochure says, I should be good to go, and still have a safety margin.
Lets hear from the "old pros". - goducks10Explorer
TomG2 wrote:
Since the average F-150 is good for about 60% of the 11,500 pound rating, then the 2.7 should be good for about 60% of the 8,500 pound rating. Wonder what the payload numbers are like for a typical model?
So is the average 3/4-1 ton only good for about 60% of the rated tow rating also. That would mean I could only tow 7440lbs with my 12 Ram 2500 CTD. Not quite following the your logic. - TomG2ExplorerSince the average F-150 is good for about 60% of the 11,500 pound rating, then the 2.7 should be good for about 60% of the 8,500 pound rating. Wonder what the payload numbers are like for a typical model?
- APTExplorerTC as in Truck Camper? I don't believe any 2.7L equipped F-150 will have enough payload for one. Towing, it should do fine if kept below all the truck's ratings.
- coolmom42Explorer II
skipnchar wrote:
700 lb. won't make up for the loss of displacement but it'll still do pretty well. With the smaller V6 they have lowered the maximum trailer weight from 11,300 lb. to 8,500 (or something like that) so that should tell you something about it's capabilities. Probably as important is you probably can't get the HD option with the smaller engine so payload will be reduced when the small engine is selected.
Yep, payload will be the limiting factor. But this truck would probably be a great match for a small light trailer. - TystevensExplorerI haven't seen one on the road yet, as far as I know.
Based on my experience w/ the 3.5 EB, I expect the 2.7 will tow just fine within its ratings. My 3.5 certainly gets the job done.
And no, it won't get any better mpg than anything else when towing! - skipncharExplorer700 lb. won't make up for the loss of displacement but it'll still do pretty well. With the smaller V6 they have lowered the maximum trailer weight from 11,300 lb. to 8,500 (or something like that) so that should tell you something about it's capabilities. Probably as important is you probably can't get the HD option with the smaller engine so payload will be reduced when the small engine is selected.
- wompsExplorer
Terryallan wrote:
Can you even buy one yet?
Yes, they are on the dealer lots.
44,044 PostsLatest Activity: Jul 29, 2025
