pld33270
Jun 29, 2018Explorer
Our trailer new leaked from the "hand tighten" connection (one with typically 3 wing grip) at the toilet the first trip out. I hand tightened it, problem solved. A couple of trips later, much less water leaking behind the toilet. I finally figured out the vacuum breaker was leaking. ~$20 from Amazon and 20ish minutes of work and the vacuum breaker was replaced. No more toilet leaks. It has been used connected to city water and the onboard fresh water system. No more issues.
44,056 PostsLatest Activity: May 04, 2014
