brholt
Mar 17, 2013Explorer II
cdbinns wrote:
We are new to truck camping and have not yet purchased a truck or a camper. We've done a lot of reading and ideally would like to purchase an Arctic Fox 1150. The truck we are interested in is a 2013 Ford F350 4x4 Crew Cab Long Bed Diesel DRW. Based on the weights published on the Ford site, it looks like we would be able to carry the 1150 and be within the 14,000 GVWR limit. However when we test drove a truck, the camper certification in the glove box said the limit was 4460 lbs, which means the 1150 would be over the limit once it is loaded for camping. It looks like the AF 990 might be pushing the limits as well. I'd like to hear from others that are carrying an 1150 on a comparable truck - have you weighed your rig when loaded? Is it under the 14,000 GVWR limit? How does it handle? Did you need any modifications (airbags, stable loads, etc)?
Thanks,
I faced the same issue when I was looking to purchase a truck to carry a 1150. I ended up going with a 2013 F350 CC DRW with the 6.2l gas. One of the reasons, though not the only one, was the payload capacity. You lose about 900 lbs with the diesel. Here is the payload sticker:
And here is the truck camper insert
So far I have been pretty pleased with the combination. The only modification I have made is to add Stable Loads. With them the truck is level.
44,068 PostsLatest Activity: Jun 21, 2026
