Ranger_Tim
Nov 18, 2018Explorer
You may be over the GVW by about 500 lbs. if you keep to the 4K weight you stated. The truck will probably be okay but the wheels are the weak link. My Wolf Creek is 2100 lbs. dry per manufacturer but really is 3200 lbs after I loaded it up with options and stuff. That puts me at 11,200 lbs at a Cat scale. The Arctic Fox is a heavier camper but warmer too. If you are gas not diesel you may be closer to the GVW.
I could drive through most any snow with my rig loaded as long as it is not too crazily uneven. And who cares about being "that guy?" You must be behind me sometimes! I pull over to let the speed demons by every 10 minutes. Too many deer and elk around here to chance getting whacked.
