jaycocreek
Nov 19, 2018Explorer II
No, as in, I won't buy a camper that will result in being intentionally overloaded. I know overloading is a heated issue at times on these, and other forums, but it's not relevant to this post because it's not a risk I'm willing to take from a legal liability standpoint.
It is hard to do if not impossible with a F-350 SRW with TC with a slide..
Example:
My F-350 DRW has a payload listed on the door at 4600 lbs..I do not think there is a SRW with that amount of payload.Point,my 9.6 Lance non-slide with a listed weight of 2582 pounds loaded ready to camp and with my tools/passengers/horse mat etc and gas tank filled up on the truck,is within a couple hundred pounds of being Max GVRW..
Any slide TC would Max or even over Max my listed weights(GVRW) with it empty..I would be over weight with the AF-990 and the Lance 995 if I payed attention to the manufacturers ratings.
You will be over weight with either the AF-990 or the Lance 995 on your SRW..But many do it with less truck than you have.
