Camper8251
Nov 24, 2018Explorer
So, I would assume that you are camping out to go skiing / boarding out there in the winter...
I have an AF811 and have been camping many a winter at the slopes in Washington and BC. Its a four season camper but make no mistake if you are burning LP you are going to use a lot. On the hill if they have plugins you should get a supplemental Electric heat system. While they claim to be four seasons it can get mighty cold in the camper, and the LP doesn't flow as good.
I would also recommend insulating the windows and putting a switch on the basement fan to keep it running 24x7 to keep the heat circulating thru the "heated" basement.
I also added an electric mattress pad and insulation under the mattress.
